2015 ram 5.7 check engine light after cai install
louis whiteside
ms.
So I have a 2015 ram 1500 5.7 and recently put a exaust on it and a cai,well after I installed the cai I got a check engine light code was p0113 I believe for the sensor in the long tube,I have left the battery unplugged replaced the sensor but still have the check engine light,and it seems my msd doesn't work since because I never see the eco pop up on my dash any suggestions
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
So I have a 2015 ram 1500 5.7 and recently put a exaust on it and a cai,well after I installed the cai I got a check engine light code was p0013 I believe for the sensor in the long tube,I have left the battery unplugged replaced the sensor but still have the check engine light,and it seems my msd doesn't work since because I never see the eco pop up on my dash any suggestions
Like crash said, that code is for the bank 1 exhaust camshaft ocv (oil control valve). Probably jimmied the wiring when installing your cai.
Administrator
The ECM is seeing a problem with the sensor, the error code states "circuit high". That means the expected voltage reading from the sensor is too much. It's possible if you put a new sensor in that it's bad or there's a bad connection.
L
louis whiteside
ms.
So a volt meter would be needed to check,and yeah I bought the new sensor from dove dealership
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
The probe is very sensitive and if you touched it directly while installing would throw off readings. Try cleaning it with MAF cleaner first
