Mylt1
Kinda new here. Just purchased a 2015 Ram 1500 Big Horn crew cab and looking to improve the lighting on the truck. I know the CAN-BUS is a little different for the 15's and newer so the question is, which lights can be changed without needing to run adapters/resistors? and what adapters/resistors have you used with long term success in the lights that do need them? I want to change out the low beams with the Phillips LED's since they seem to have a pretty good beam pattern even in the stock headlights and provide a little more light output. And i want to change out the front and rear marker/turn/stop lights as well as the reverse lights. I would much rather have an adapter than to wire in resistors but if i have to go that route(resistors) i will build my own adapters so i dont have to mess with the factory wiring. Thanks for any help.
