Davids442
Good evening everyone. Having a rear park sense issue. So far, all 4 rear park sensors have been replaced and the wire harness for the sensors has been checked and it's fine. When I back up, the sensors work fine, the back up camera works normally. When the truck is put into drive and you approach about 8 mph, you get the ding and the message Service Rear Park Sensor appears on the instrument panel and then you get the Park sense disabled message. Currently, the park sense button on the center console is illuminated and when you press the button, nothing happens. When you back up, the message disappears and it operates normally. I thought I would ask everyone's opinion before I go any farther with the diagnosing. Thanks for your help
