2016 ram 2500 won’t start
Smoher
Canada
I have a 2016 ram 2500
Got up one morning started fine no codes or than gas gap
Shut it off at work went to restart it 5min later nothing
Scanned it came up with error code p1524
Look it up says oil pressure sensor or oil filter
Changed the oil changed oil pressure sensor still won’t start
It has lots of power (even tried boosting it didn’t work)
Where do I look next
Define "nothing" ?
As in nothing happens when you attempt to start? Does the engine turn over?
If the engine turns over but doesn't start, check the fuel pump.
S
Smoher
Canada
It won’t turn over…. No crank
I can hear fuel pump running.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
If your battery is good and a boost didn't help you may want to check all the battery connections.
S
Smoher
Canada
I have it’s all good there
Even tried unplugging battery (after cleaned terminals) for 30 minutes to reset computer after replacing parts to clear code. (P1524) The code still there and I can’t clear code till it’s running. But won’t crank.
mtnrider
Georgia
Did you have the battery load tested? I know everything turns on but if the hemi is anything like the cummins it will not start if it has a dead cell (but everything else will still turn on). "jumping" it doesn't always work either
