Abb1
hi I have a 2017 ram 1500 with bucket seats and my power outlet closet to the steering wheel didn’t work. Fuses all check out good. After checking everything out I only had like 1.5 volts to the back of the outlet with the key in the run position. After some tracing I found a plug under the drivers seat is where I lost some power after unplugging and plugging it back in I get like 10.8-11 volts but it still didnt work so I got a new outlet socket and put in and the same result. I am about 1.5 volts less then the one in the back seat I would think the charger would work at that but I get nothing. I checked the wire at the back of the fuse box and get around 12.2-12.4 so not sure where the loss is. If the truck is running my 11ish volts turns to 12.5 but still won’t run anything any ideas?
