giantsean
Hi all,
I bought a 2019 Big Horn in Sept from Carmax (I know... I know). It has actually been pretty good save for the other day when the satellite signal went out suddenly while driving, and has been displaying the dreaded "Acquiring Signal" message since. Tried the usual reset, resend signal, yadda yadda. SXM blamed hardware so I took it back to Carmax who gives me a 90 day warranty. As expected they said they hooked up their "scan tool" and received no fault codes from the radio or the antenna. Being a former auto tech and current IT guy, I was a little skeptical their tools get so granular, but I didn't press it. I called RamCares and they pointed me to a dealer portal update which I mailed to Carmax. Carmax called the local RAM dealer and confirmed it needed an update, but that they wouldn't do it and pointed me to the Uconnect site, which of course we know how helpful the VIN lookup tool is. They also gave me a TSB which requires DealerCONNECT access, which I do not have.
I am skeptical that a software update can fix this in the first place, but need to do it to get to the next step. I can see this turning into a three-party cluster in short order.
Questions:
- How can I get into dealer mode or check firmware version on a non-Nav UC4 unit? Every set of steps I have tried (two fingers, hold down buttons, etc) has had zero effect
- How can I find the three digit code (ie UAM, UMM) for this unit?
- Does anyone have a link to the latest version of UC firmware for non-NAV? (I have seen the threads for Nav)
- If as expected the firmware update does not bring back SiriusXM, what is the next logical step? Is this problem normally due to head unit, or the antenna (hoping not the antenna as it appears to be a leak hot spot and I'd prefer to leave well enough alone)
The only mods I've done to it since I bought it were to install a tonneau cover (Bak Revolver) and side steps. I did break off a step bracket stud and had to drill out and re-tap the stud to take a bolt, but I am guessing the antenna wiring does not pass anywhere close to the rockers.
Thanks for any advice!
Questions:
