Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2019 3500 CTD HO 4x4 Crew Cab SRW and 16500 lb 5th Wheel
Discussion in 'Towing & Hauling' started by Blazin383, May 20, 2020.
  1. Blazin383
    Blazin383 Senior Member
    101
    27
    Jan 10, 2015
    Pacific Northwest
    Ram Year:
    Engine:
    6.7 CTD
    I'm new to the Ram diesel and have a question regarding towing my new 5th wheel. I traded my 15 Ram 2500 6.4 Hemi w/4:10 for a 2019 Ram 3500 HO Cummins single rear wheel.
    Until this weekend my toy hauler was a 26' tow behind that the Hemi pulled just fine, but the Cummins scoffs at. That trailer, loaded with gear and a 1700 lb side by side tipped the scales at about 10,500 lbs. However, on our way home to WA from Moab last weekend we made the mistake of stopping in UT and buying a new 40' Torque 371 5th wheel that weighs about 14,500 empty with a pin weight of 3200 lb. Obviously the weight will only go up from there with toy, fluids and lots of stuff!
    I'm preparing the truck in anticipation of driving back to UT this weekend to pick up the trailer. I'm in the process of getting a B&W flip over ball hitch installed in the truck, and have decided to go with the Andersen hitch because of the overwhelmingly positive reviews and it's light weight. My payload rating is 3633 so I know the payload limit is getting real close.
    Is this trailer too much for the single rear wheel 3500?
  2. MADDOG
    MADDOG Cummins Driver Administrator Supporting Member Military
    11,717
    5,672
    Dec 26, 2011
    Apache Junction, AZ
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    Yup...you might be over because it appears you haven't included the weight of gear, hitch, passengers and other stuff inside the truck with the pin weight of the trailer. It all counts as payload weight.
    You've added a ton, literally a ton - 2000 pounds of tow weight - before you even add any gear to the trailer as well.
    Another thing to note is the pin weight calculation. Is that max pin weight or is that pin weight of the trailer when it's empty?
    What is your trailer's Gross Vehicle Weight Rating?
  3. TWILLIAMS9
    TWILLIAMS9 Senior Member
    668
    369
    Apr 12, 2014
    Ram Year:
    Engine:
    Your payload is only 3600? I have a 3500 Laramie mega cab SO and mine is 4200.
  4. RandomRam
    RandomRam Senior Member
    147
    100
    Sep 10, 2018
    Oregon
    Ram Year:
    Engine:
    The Aisin in the HO is like 150lbs more. Not sure what the rest would be.
  5. Blazin383
    101
    27
    Jan 10, 2015
    Pacific Northwest
    Ram Year:
    Engine:
    6.7 CTD
    I'm assuming the 3200 lb advertised pin weight is the empty figure. Will putting a 1700 lb side by side hanging behind the axles take any weight off the pin?
  6. Blazin383
    101
    27
    Jan 10, 2015
    Pacific Northwest
    Ram Year:
    Engine:
    6.7 CTD
    My truck is a loaded Limited version, and apparently all that bling must be heavy!
  7. sandawilliams
    sandawilliams Senior Member
    2,011
    3,736
    May 29, 2012
    Pueblo West, Co.
    Ram Year:
    Engine:
    6.4 hemi
    When I bought new in 2014 the payload for the diesel was quite a big lower than the 6.4 because of the added weight of the engine.
  8. TWILLIAMS9
    668
    369
    Apr 12, 2014
    Ram Year:
    Engine:
    that’s always been crazy to me how the added features take so much off the payload. The only feature I don’t have would be the moonroof.
  9. TWILLIAMS9
    668
    369
    Apr 12, 2014
    Ram Year:
    Engine:
    That would make sense
  10. chri5k
    chri5k Senior Member Supporting Member
    606
    782
    May 24, 2019
    USA
    Ram Year:
    Engine:
    Diesel
    Take the rig to a CAT scale and get the actual numbers for each axle with your normal load of stuff. Only way to know for sure all the effects of water / waste, and stuff inside the trailer being either in front of or over the axles and the SXS, tool box, etc slightly over or behind the axles. All of those factors will affect the pin weight.
Share This Page
