2019 Cummins 2500 Electrical Issues- Huge Mystery
PTurn01
Iowa
Hello,
2019 Ram Cummins 2500 4x4 Bighorn-
119K Miles, very well maintained, no wrecks, fires or hard use
Issues-
Passenger Headlight not working (bulb replaced, all other lights work) No code
Voltage jumps (new batteries this year, connectors are clean, wires appear to be solid) No Code
Passenger air bag code Boo7A-13 Circuit open (no physical symptoms; pretensioner never fired)
ABS/Brakes Code C2100-16 (no physical symptoms, everything seems to work)
Rough Idel in park occurs randomly- No code
Throttle body sensor throws the "lightening bolt" on the dash once in a rare while and then disappears with no code
High fuel pressure code Has come and gone a few times (don't have the code on hand)
Backup camera just stopped working (when in reverse the radio does nothing, no options left on radio to edit rear camera; completely gone now)
Passenger side auto window acts up sometimes as well.
Interior lights had dimmed off and on in the past
All started right around the same time, 3 mechanics and 2 dealerships have tried and failed. I've reset the TIPM a few times, checked fuses, tested alternator, batteries and had other scans with no luck. Truck still starts and drives but I'm getting worried as I do not need to be broke down 500miles from home.
Any ideas????
P
PTurn01
Iowa
Fixed pass. Light- ground plug burned out.
New issues- truck will not start.....
Still no new codes
New batteries (CCA790) load test at 450L 400R... 12.6V to starter. Starter does not engage (its a new starter).
Mechanics are guessing starter as a hail marry but no one can figure it out. Checked relays, fuses, wires, ground.
Possible push start issue? Does the same thing with remote start.
It clicks over to run but makes no attempt to turn over (like a dead battery). Both batteries are fully charged 14.1V total system. 12.8V to 12.6V each battery.
