electrical issue
  1. H
    Fuel pump or wiring?
    Vehicle: 06 Dodge ram 1500 hemi 5.7 2WD Symptoms: turns over but starter seems week. Past few months, intermittent stalling issues at idle but usually only happens once per drive. Past 2 weeks, hard start, have to pump to get it to start. Now weak crank no start. NO DTCs Live data TPS...
  2. G
    Truck intermittent cranking, speedometer stopped working, and message says 4 wheel drive unavailable randomly. Any insight?
    I have a 2014 ram 1500 5.7 recently my truck will not crank when I turn the key sometimes I have to try up to 10 times starter not turning over at all and no noise then will randomly crank. Also my speedometer will quit working for a few seconds and come back on l. As well as a randomly 4 wheel...
  3. J
    Wipers don’t turn off
    So I’m at the point where I don’t know what to do next. The issue is that the wipers run on constant low, no matter what, when the fuse is installed. The only way the stop is to pull the wiper fuse. No other functions from the selector switch change anything. They even run on constant low when...
  4. C
    2017 1500 Laramie Electrical Issue
    I’ll apologize for the length in advance. I’ve had this truck since July of last year. New battery had just been installed when I bought it. Ran flawlessly until one morning in January when it wouldn’t start. Fine when I parked it that night, woke up to go to work and it just clicked. Took...
  5. M
    No Electrical Power
    Have a 99 v8 Dodge Dakota Sport. Got hit in the tail end, barely any damage. Drove home fine and ran fine. Next morning I go to start it up, had dash lights and all, but when I turned to start a very noticeable clunk or pop happened. The truck now has no power whatsoever, dash lights...
  6. Y
    Gauges not working
    I’ve got a 2006 ram 1500 5.7L Hemi. I don’t drive this vehicle in the winter as it’s been redone cosmetically and I do not want any rust ( Ontario winters ) I had parked the truck for the winter (I removed the battery due to battery drainage from my stereo) in fall of 2023 and returned back to...
  7. C
    Need a little help with this mystery shifter lockout
    So I put my 2015 Ram 2500 Hemi in park at the McDonald's drive thru a couple of nights ago and ended up stuck at the window for 25 minutes trying to shift out of park. Whenever I would pull forward on the shifter, I would hear a clicking from the base of the shifter (inside the steering column)...
  8. L
    And / traction control lights on and 4WD is disabled
    I have ohm tested rear speed sensors, I have replaced the front sensors and I still can not get my traction control and ABS light to go off. I have ohm tested all sensors against the new ones and all are very close in resistance. What else could be causing my issues any help is appreciated
  9. J
    Electrical short?
    Went out to start my 2021 Ram diesel 2500 and pressed brake, pushed button and it clicked then cycled through a bunch of warnings - fuel filter, trailer towing, and about 4 other things and won’t start. Tried again about 12 hrs later and same thing. Now I have to get it towed out of a parking...
  10. T
    Electrical issue
    I had my Electronic power steering go out. I let it sit for two days and when I went to turn the truck on there was no power to the truck at all. I replaced the battery, checked all the fuses and relays and the only thing that turns on are the dome lights and the power locks. I don’t know what...
  11. U
    2012 Ram 1500 5.7 No Power
    Hi all, I just went outside to pick up my little guy from school and my truck wouldn't start. No power at all when I opened the door and inserted the key. Nothing. I figured I must have left something on when I and drained the battery. Grabbed a jumper pack and still nothing. Pulled the...
  12. P
    2019 Cummins 2500 Electrical Issues- Huge Mystery
    Hello, 2019 Ram Cummins 2500 4x4 Bighorn- 119K Miles, very well maintained, no wrecks, fires or hard use Issues- Passenger Headlight not working (bulb replaced, all other lights work) No code Voltage jumps (new batteries this year, connectors are clean, wires appear to be solid) No Code...
  13. WillT
    tow mirror signal lights quit working
    Hi, I have a 2015 Laramie Ecodiesel with tow mirrors, I noticed about 8 months ago that my driver side signal light on the mirror quit working and now the passenger side quit as well. I have noticed a small crack on the light on the driver side, but there is no moisture inside and the passenger...
brixten
