2019 Laramie Add Power Fold Tow mirrors to replace manual
My 2019 DT not classic, came with Tow Mirrors with manual fold. (BSM, Heated, Temp Sensor, Puddle lights, power adjust mirror)
I'm wanting to replace my manual non power fold to power fold version.
I understand I need to replace the Door Modules; Drivers switch and replace the mirrors with the power fold function included.
Looking for part numbers:
Drivers Door Module?
Passenger Door Module?
Switch panel?
What are your thoughts on these Non-OEM parts?
Mirrors - https://ebay.us/m/tqyzqG
Switch - https://ebay.us/m/4Bzdsd
I do have Alpha OBD to do the changes.
Thanks for any help
xtryfun
US
You’re on the right track. On a 2019 DT you’ll need:
  1. High-line DDM & PDM (door modules that support power-fold),
  2. Driver’s switch panel with the fold button,
  3. Power-fold tow mirrors, and
  4. Possibly door harness pins if your truck isn’t pre-wired.
Before buying parts, pop the door panels and check the mirror connector: if the extra pins for the fold motor aren’t present, plan on adding wires or swapping harnesses. After install, use Alpha OBD to enable power-fold, tow-mirror, BSM, puddle, heat, etc., in both door modules and BCM.
Non-OEM mirrors: they can work, but common issues are glass vibration, weaker motors, and iffy BSM/temperature sensor performance. If you go aftermarket, make sure they’re DT-specific, tow-style, and list support for BSM + puddle + heat + temp sensor. I’d still lean Mopar mirrors and a used pair of high-line modules from a DT donor. The switch can be aftermarket if it’s DT-specific.
Tip: match module part numbers/revisions to 2019 DT to avoid CAN complaints, and sync window calibration after flashing.
Anthony Bulger
I have 2 sets of Door modules part numbers. Not sure which would be best to choose from.
2019 part numbers
RF - 68424178AC
LF - 68424179AC
2022 part numbers
RF - 68517698AB
LF - 68517699AB
I know the 2019's didn't offer the power fold in the tow mirror, but I would assume the power fold sport mirror module is the same.
The 2022 part numbers I got from a cross-referenced on a VIN for one with power fold tow mirrors.
ChloeBrooks
