Crybbyem
I installed an upgrade cam and found someone to do a tune but when I picked it up there were multiple codes and after fixing everything is still in a limp mode has anyone had any similar problems if so what was the solution
Pull the valve covers and make sure all the pushrods are seated properly,then find yourself a decent tuner,as it sounds like you found Joe Smo to tune it for youI installed an upgrade cam and found someone to do a tune but when I picked it up there were multiple codes and after fixing everything is still in a limp mode has anyone had any similar problems if so what was the solution
