2020 2500 6.4, soft frt. suspension?
ridgeracing
Pa
2020 2500 Tradesman
Purchased new with snow plow package and frt end has always been soft, and I do not even have plow kit installed. Has gotten worse in 5yrs and 70K miles. Just going over wallowing back roads at speed it bottoms out, not to mention if I even hit a hard bump, goes right through steering wheel! Front has settled a little more as well. Looking to stiffen frt and raise 1-2", any good recommendations? I would like heavier/longer springs, not a big fan of blocks. Thuren/Carli?
mtnrider
Georgia
Sounds like you are really going to need some sort of HD spring with the plow, which Carli and Thuren are Not. They will be even softer then stock. You sure your shocks are still in good working order?
rzr6-4
nebraska
'09 2500
I put an Eibach level on mine. Not only does it lift the front but the springs are stiffer too. Might work if you are OK with the leveled look.
