jllupin33
Anyone here experience a loud whine from oil pan area on cold starts? The noise is most noticeable at startup and 1500 rpm’s and goes away after driving for 10-20 minutes. I’ve been chasing this for awhile - had the etorque replaced (brand new) by dealer under 80k warranty, new pulleys/tensioner on the drive belt side, new drive belt, no sound on anything else, like ac compressor, water pump. Drain and fill on transmission, no noticeable signs of metal at all. Changes diffs and transfer case oil. I was hoping one of these would resolve the sound but no luck. I’ve traced it back to the oil pan area and I’m starting to suspect the oil pump, but oil pressure stays above 30 psi and never goes above 60. One thing I noticed the other day is I can feel a random jolt while driving those first 10-20 min and the oil pressure jumps for a few seconds and comes back down. After it’s warmed up the pressure stays constant and no more jolt - it only happens once. Is this normal for these engines to whine like this? Maybe I need to use a different oil..I’ve tried both 0w-20 and 5w-30, no change? TIA!
