crazykid1994
Yes. The only difference is the spacer. They use a 4” spacer in the 4” and a 5” spacer in the 6”. No that’s not a typo. The biggest consideration is your ride. What is your bilstein 6112 currently set at? The 4” spacer and bilstein at 2”is 6” lift either way. Going to the 5” spacer only gets you 1” more front lift either way. Also bilstein recommendation goes out the window as soon as you put a suspension lift on the truck anyways. The suspension lift should keep all stock geometry so setting the bilstein up to 2” or 2.6” should not max out the suspension
