2021 ram 3500 cab chassis can’t get low beam headlight out because wire seems to be pinched inside assembly.
FlyingKRanch
OK I switched out the passenger side low beam without an issue plenty of wire to pull the bUMB out and get it exchanged. When I went to the driver side I can move the bulb enough to get it unhooked from its landing spot but not enough wire even to get the bulb out of the assembly let alone out of the entire headlight bucket feels as if the wire is pinched on the right side between the high and low beams I’m afraid to pull hard on it because I don’t want to break the wire anyone else had this experience any thoughts suggestions? Thank you in advance Mark
