2021 Rebel lift for 35's
limechallenger
South of The Motor City
2014 Ram 4x4 Sport regular cab
So I'm looking at a 21 Rebel ,hemi, 4x4. I know they are already a inch higher than non- Rebels. What do I need to do to make it level and add 35's as a minimum height tire?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Just a simple leveling kit as long as that Rebel is not equipped with air ride.
BlackSheepRebel
The Matrix
@Quick_Shifter is right, but I feel like he's skipping some nuance because he's an expert so takes things for granted that bite us amateurs.
Do some research and look at people running true 35's on YT. It's tight, and most say "I never offroad" -- yeah, because serious articulation would be rubbing.
I went with BFG KO2's which are technically 34.5" to buy a little room. Leveled with Bilstein 5100's. They still rubbed at full lock -- not really full, just before. I find any rubbing annoying, and want as much extra room as possible to be able to hit a trail once in awhile (probably should have just used a real lift kit, but then my wife would divorce me vs just giving me side eye).
It's not a hard fix. I removed the stupid front mudflap things (can't even tell it's missing from the side). Trimmed some of the wheel liner plastic, and reshaped it a bit with a heat gun (go slow, wear gloves, not hard, it's thermoplastic). Also paranoid and wanted as much room as possible, so took a grinder and rounded off the area around the pinch weld then spray painted everything black. This is the one step that's not 100% necessary IMO, but it looks fine if smoothed out (doesn't get all the way into the weld or impact the bolts) and gives you a little more room.
This was my experience getting "almost 35's" on a 2021 Rebel. YMMV. I have the worst luck. :)
Overall, I think it's worth it...wanted to level anyway, and the extra 1.5" of axle height is nice too.
Let us know how it turns out!
Nick@GotExhaust
Supporting Vendor
SC
We can assist you with adjustable struts that will lift/level the front of it. message me if you would like a quote
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
That is what the forum is for to ask questions and design a kit. The variations our trucks come is appalling your rebel could literally sit 2" lower than the OP or vice versa Before we touch anything the tape measure comes out and we dial in every ram we touch. A lot of modifications are not blanket mods that work for everyone. With the various wheel offsets and height inconsistency we find ourselves back on the forums educating ourselves more and more
Nick@GotExhaust
Supporting Vendor
SC
100% correct. A lot has to do also with options and additional modifications adding weight. More weight the lower the truck may potentially sit. That coupled with manufacturing discrepancies, tire actual size, wheel offsets, etc....there is no one size fits all, its more like fits most.
jaccard30
