2022 ram 3500 limited GAWR min max
David Simmonds
Lehi, UT
6.7 diesel
I used a vin decoder that showed me a rear GAWR min of 7000 and max of 9300. Huh? What does min and max imply? My door shows 7,000lbs GAWR for rear. I do not have a dually. It's a crew cab 8' bed 4x4 3500 diesel.
2003F350
6.7 CTD
Sounds like your VIN decoder didn't really decode your VIN. What it's telling you is that the minimum GRAWR of your truck would be 7k, and that properly optioned the max would be 9300. It basically looked up a chart and gave you chart values.
2003F350
6.7 CTD
Mine is 9750, but it's a dually. Since you don't have a dually, yours is the lower number like the door sticker says, 7,000. There's no mystery here.
This right here. It might vary depending on options, but with it being a non-dually it is likely on the lower end.
