2022 Stereo Install - Locations Etc
VdubBry
Hey all, Just got rid of my 2013 1500 and got a 2022 1500 Big Horn Crew Cab. It has the 8.4" Uconnect, non alpine system. I checked and there is some sort of electronic under the drivers seat, amp?, not sure what it is and searched and am not finding much info yet.
I took all the old gear from my 2013, so I have (2) Rockford amps, a 1000 watt for the (2) 10" JL Subs, and then a 500 watt amp for doors. I had tied it all in my last truck with a JL Clean sweep and it sounded amazing. I am missing that sound so want to get on this one asap, just having trouble finding wiring diagrams, and where everyone has found space to mount, disassembly information etc.
Any info or links is much appreciated!
Kelvint
Herndon
I am in the same boat as you. Have you found any info on adding amps yet ?
woojyee
Nebraska
Hemi 5.7 eTorque
That silver box under the seat is the Active Noise Cancellation (ANC) and you will need a PAC AMPPro AP4-CH41 r.2 to interface with the radio to get a clean signal for amps, a AP4-CH41 to bypass the ANC and to access the factory speaker wiring. The 2022 Rams have a Uconnect5 and you will need the PAC APHCH42 wiring harness that replaces the original harness in the AMPPro. They should be releasing an updated AMPPro with the new harness soon enough otherwise you will be spending extra to get started now.
This is a video of me doing a reinstall of my gear as the shop I paid did a horrible job, this will give you an idea of what all needs to happen for a custom install.
