Lineout Converter 2016 Ram 1500 Base System
mattokc
ok
5.7 v8 SMPI
New Owner of 2016 Ram 1500 w/ 8.4 Uconnect Base Audio System. I am installing CT Sounds Line output converter for amp/sub only. I tapped into (what I thought) was the rear driver side speaker at the pilar. Everthing works as far as power goes, door speaker works etc. No signal from the tapped line into the lineout box. I even tried bypassing everything and connecting sub directly to see if I could get any noise comeing out and nothing. Crazy thing is that I am getting signal on the tapped line until I go and connect it to line output. Checking with multimeter the signal coming in at lineout is fine if I bridge it (left + right -) but connecting ( left + and - ) zero signal even jumped and signal goes away. Any help would be great. Base system no, factory amps or subs, factory speakers still in..
KAKA
