2025 Ram sst ho
agio
NY
SST HO
New to the forum, hope this goes well. Intermittently, while stopped at a light, the truck revs erratically, the puts itself in Park, and applies the emergency brake. Brought it to the dealership 3 times, last trip the said they couldn't find the problem. I get no check engine or other error. Anyone help out, thanks.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Be careful, there have been a few trucks with reported sudden acceleration.
RamDiver
Marlborough, Ontario Canada
2021 DS
Welcome to Ram Forum. :cool:
The search utility in the upper-right will find numerous threads discussing various failures in 2025 & 2026 model trucks. Both of these years share the I6 dual turbo and the newer Atlantis High electrical architecture.
The following article has identified ground faults and a 12-volt power system that is unable to regulate the voltage sufficiently with the turbo system. This lack of regulation creates problems for the computer modules, resulting in a myriad of problems.
The issues vary from minor inconveniences to sudden explosive runaway accelerations, as mentioned above by Mpgrimm2.
Key Takeaways
  • Identify structural voltage drops rather than accept simple software-glitch explanations from factory service centers.
  • Inspect and clean factory grounding blocks down to bare metal to eliminate high-resistance points.
  • Monitor dashboard behaviour during high-load scenarios, such as trailer towing or high-altitude mountain ascents.
  • Upgrade to a premium battery to provide a stronger electrical buffer against high-amperage powertrain components.
I would consider the recommendations covered in the article, especially refurbishing all of the common ground blocks, as well as adding 'The Big 3' electrical mod, and an H8 AGM battery.
