207 Ram 1500 Wheel/Tire Offsets
TBTn7
USA
My first post!
2017 Ram 1500 Big Horn 4x4
I have the following parts but not yet installed:
Bilsteins set at 2.1"
20x9 wheels w/ 34.1" tall x 11.25" wide tires (mounted)
Wheel backspacing is 5.75" measured from inside mounting surface to edge of wheel (positive offset?)
Tires measure 6.375" from inside mounting surface of wheel to backside edge of tire
Looking at the very informative! tacked post on leveling and doing the numbers, IF these will fit my truck without rubbing somewhere, they will be just about flush with the fenders. I was hoping to have a slightly aggressive look.
What do you all say about how much, if any, the tires will extend beyond the fenders?
Thanks TBTn7
quietpeen
2021 TRX
Hellcat
The wheels actually match stock 20x9 wheel specs so you are not going to be sticking out much further than stock tire’s much at all.
What is the advertised size of the tire?
yortnodnarb
Adrian,MI
Sounds like a 285/65/20 tire so yes the should fit just fine and no you wont have an aggressive stance with stock wheels. Could always get a set of wheel spacers though.
T
TBTn7
USA
The tires are Firestone Destination MT LT275/65R20
T
TBTn7
USA
Spacers don't excite me but that may be my only option at this point. Thanks
quietpeen
2021 TRX
Hellcat
Yea you will be set up just like any stock ram with the 20’s. Only difference is a taller mud tire. Not saying the mud tire won’t look good and aggressive...just won’t give you any wider stance
T
TBTn7
USA
This is what happens when you don't get on the forum and ask questions! Thanks to all for the replies.
southalum
