22" wheels with 2" lift
talgozzine
Been searching for days and having a hard time finding any pics of a Ram with something along the lines of Billstein's set at 2.1 or 2.8 in the front, 1" block in the rear and then 22 inch wheels with 35" tires. This is the look that I THINK I want, but I'm nervous without seeing some pics. I did see a white truck with the above suspension with black 20's, but I'd really like to see 22's. Hmm, is there a reason nobody has this setup with 22's? Are there fitment issues? Thanks in advance!
TXKID
Houston, TX
35's should definitely not be an issue with the right back spacing/width of your rim
T
talgozzine
Cost. Holy crap are big tires for big wheels expensive!
I personally don't care for the 'lo profile mudder' tire look at all.
Yea, I think you might be right. I did some searching for actual tires right after I posted this and not much is feasible price wise except maybe a 285/55R22 Nitto Terra Grappler at around $375 a tire...yikes!
Wandell
Cummins 6.7
Yep, 22 inch wheels and tires are expensive. That's why I'm running 20's instead now (not that 20's are cheap).
