2500 4X4 diesel engine oil temp
sb2013
texas
what is everyone seeing on average healthy oil, Trans and Coolant temp?
chri5k
USA
Diesel
MY 2016 shows the engine oil and coolant at the same temp, 180 degrees, +- 2 degrees or so of each other unloaded. Trans around 168. Hauling heavy (13,000 Lbs) around 195 - 210 for both engine oil and coolant. The trans shows 172 - 174.
jejb
NW Arkansas
This was near the summit of the twisty, east bound Monarch Pass, CO climb on a warm day. Pulling an 8K enclosed trailer, 18 Ram 2500 Cummins. I was not taking it easy. Such a stress free truck to pull with.
Dean2
Near Edmonton
Interesting, my 2021 6.4 in the 2500 runs Oil and Coolant at about 212-4 F running empty, Transmission about 168. Ambient air temp was 70 F. Interesting to see the Diesel transmission runs very close to the same temperatures.
mtnrider
Georgia
There is a thermal bypass that regulates the trans temp to stay right around that ~168 mark. Of course it can go hotter if being worked real hard on a hot day.
runamuck
Air Force
dfw
6.7 dsl
trans 173* oil and coolant 210*
Oil temperature and pressure on the Cummins is a calculated value, only sensor is the low pressure switch to prove there is some pressure (> 7 - 8 psi)
Glowz
