Exdeus
- Apr 2, 2013
- 201
- 167
- 2017 RAM 2500
- Cummins
Greetings all. Currently own a 1500 HEMI and am looking to swap it up for the 2500. There seems to be a ton of information out there, but with such a big purchase, I feel better asking y'all for your personal experiences prior to making the jump.
This will be my daily driver and I drive approximately 50 miles per day for work, five days per week. Most are back country roads and highway, running from 45mph - 75mph, likely averaging around 55mph.
I will be adding 10-ply tires and lifting the truck with after market accessories. I essentially will be placing the AEV 3" lift, 35 to 37" tires, bed rack and supporting a roof top tent in the bed with refrigerator.
I will use this truck for multiple long range trips throughout the year, several thousand miles each time (for example, have a 2,000 mile trip end of this month).
I will ultimately use this truck as a daily driver, while also using it to explore and off road. I know PW is an option, but not sure I need the sway bar disconnect and can add in lockers later.
In regards to towing, I do not tow at the moment. I will, however, likely be getting a pull behind camper in the range of 5,000 - 9,000 pounds for some of our national park trips as a base camp.
Used I am finding the Laramie Cummins and PW Hemi to be about the same price range.
Appreciate y'alls experience and insight. I am leaning towards the Cummins, but the PW with Hemi also seems promising but has quite a bit lower MPG from what I am seeing which is concerning as a daily driver.
Thank you!
Edit: Also, would anyone have any reservations buying a used one that had a fifth wheel tow point attached to it? I know they are built for it, but looking at a mega cab with 40,000 miles on it that has a fifth wheel attachment point from the prior owner.
Thank you!
