2500 lifted/leveled diesel
brian
cummins 6.7
ive been tryin to navigate through this forum and i cant seem to find anyone with a lifted truck that pulls a gooseneck trailer ? is there anyone out there with any pics and suggestions on how high to go to pull my trailer in a safe manner ?
quietpeen
2021 TRX
Hellcat
hi, welcome to RF
I moved this to the towing and hauling section. hopefully that generates a answer for you.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I think there may e one newer member who pulls a gooseneck with his dually but I'm not sure if he would have any idea about lifting.
I pull about 14k lbs from the bumper of the 2500 with a 2" level and 35s without a problem (although rarely, usually anymore the 8k goes behind one of our dumps)
I would guess how high you go depends on how much you can adjust your neck and how much you are actually towing.
reddot
Wolf Point, MT
5.9 cummins
wont be using mine to pull a gooseneck for a while still. sorry buddy.
North central Montana
2010 LB CC Diesel
6.7 CTD
I've pulled alotta gooseneck trailers and I can tell you right now that I wouldnt go much past stock as far as lift is concerned especially with a dodge since they tend to sit pretty high from the factory. A leveling kit is fine but personally I would leave the rear suspension alone. If you absolutely feel you need to lift the truck I wouldnt go more than a few inches in the rear. Another option albeit an expensive one is to go with a kelderman air ride system which allows for a good amount of lift when not towing and full suspension adjustability to return to near stock for towing. Its a spendy investment but its top quality and the ride is very nice.
TLC John
2006 RAM 1500
TotalLoadControl™ for your truck
Hi Brian,
If you're looking to add air bags, please check out our TLC™system for your truck.
TLC adds 9" air springs in a patented system that is on-demand and bolt-on - so doesn't interfere with your factory suspension and doesn't require changing the whole rear end.
If you have any questions, please check out our Vendor Forum, website or shoot me a PM.
John
Stangshcky12
Oshkosh, WI
5.9 Cummins
Have to agree with the above, I ment to adress that but forgot
The more you tow and/or te higher you go you will begin to experience axle wrap, especially with a lift block
I would recomend getting a progressive leaf spring (or spring pack cough carli) traction/ladder bars and air bags would be a good investment as well
OasisNinjaBat
