2500 Rear Axle Damper
ripping r
Old&Grumpy
earth
6.4 HEMI
Here's another thought....
My understanding is that from 18 on, there was an option on the rear differential. Some were heavier 6500 lb axles like mine....but other 2500s got the lighter 6000 lb rear axle.
Could be that trucks with the heavier axle get the damper? Probably is due to some other reason, but it's a thought anyway.
first i have heard of this.
Katy, TX
My '21 PW has it and the rear hops all over the place when I get ******* the throttle and the tires are breaking loose. If its goal was to control wheel hop, it fails.
dlromo
TX
My 18 CC LB Tradesman didn’t have it.
My 20 RC LB Tradesman does have it.
Both 6.4, 4x4
White six four
Wisconsin
I don't disagree with you in theory, however I would think that they must have benefit and be necessary in certain applications or RAM wouldn't incur the time and expense to install them on the trucks.
Thats my thought on it. With how cheap they are on the drag link weld recall they would definitely not put them on if it didn't do something. Or they think it's doing something. My 16 2500 6.4 ccsb tradesman with the off-road package has it.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Yes Sir. I hadn't either until a member here made me aware of it and we started checking the vin tags which show front and rear grawrs. I believe it was in 2018 this occurred but I am not certain. Some 2500s have the 6000lb rear axle, some 6500.
I believe 3500 srw now have a 7000 rear axle. Just some minor differences. As I understood things, for a period of time the only differences between 2500 and 3500 srw was that 3500 had leaf springs, 2500 had coil springs in the rear, but that now no longer appears to be the case. Still very similar though overall.
SOKY_RAM
Bowling Green, KY
Both 6.4, 4x4
My 21 Tradesman CC 6'4" bed 4x4 6.4L has it (non off-road pkg)
Could it be on the Anti spin differential upgrade or the 5th wheel/gooseneck prep?
ripping r
Old&Grumpy
earth
6.4 HEMI
Tried looking mine up. all i found is i have the 6,000 front and all it said for rear was 11.5. but i know that.lol maybe it has to do with GVWR mine is 10,000 i know some are 9,000 or 9,500 GVWR i dont know its cheap so i guess if someone really want to know if it helps just get one. i did buts its on back order. so just waiting for it to show up now.
ripping r
Old&Grumpy
earth
6.4 HEMI
well my wait is over. it showed up. hope to install this weekend.
ripping r
Old&Grumpy
earth
6.4 HEMI
update. got installed did about 12 miles. and i can tell no difference with it. so i would not buy it again.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Maybe it's one of those items that you dont need until you do?
Who knows. Glad you got it installed though.
ripping r
Old&Grumpy
earth
6.4 HEMI
It may be. im just glad it did not make the rear end any rougher.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
simple explanation, not detailed
Too bad the original ALLPAR site no longer exists
They always had detailed explanations for new equipment & they had some insider information from the Mopar Underground
It looks like it may be back up, just not as easy to navigate
bdc2
Ks.
Could it have anything to to do with the type of drive shaft you have, mines aluminum and have the dampener
Moose2
Iowa
I installed it on my 2017 2500 Cummins. Seemed to keep the rear end planted better on really bumpy roads.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Interesting. I have the damper and an aluminum driveshaft
