2500 springs
slader15
I have a 2001 1500 im looking to put 2500 springs in it along with my 2.5 inch leveling kit im jus wondering if i gotta get a drop pitman arm and or any other frontend parts
Thanks
Johnn123
Ontario
Yes you will need new control arms, track bar drop bracket or adjustable bar, pitman arm drop, longer front shocks. You are essentially putting a 5" lift in your truck by doing that set-up. You will want to get to some lift for the back, as you will be nose high as well.
S
slader15
Control arms?? It has a solid front axle
S
slader15
For the rear i was going to ad a leaf or 2 or put lift blocks in
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Control arms aren't just for IFS. Personally I would skip it, and do a proper 5 inch kit if you want a full 5 inches.
nathanrippey3
5.9 gas
Spring help
Does anybody know where to get a set of lifting lifting springs for a 1997 dodge ram 1500 2wd?
gville35
