285/60/20
jknappen
Kentucky
Will goodyear duratracs 285/60/20 fit on a stock set of wheels leveled with the rancho quick lift and stock shocks in the rear with no rubbing and no spacers. if not what is the biggest size I can run with this set up using duratracs?
OilCityOperator
Alberta
those will fit no problem with no rubbing with stock wheels
biggest you can go would be 35's but you would need 1/4" spacers with stock wheels
iam_canadian22
northern ontario
They fit even without a level, biggest duratrac that fits without level/wheel spacer or offset wheels unless they came out with new sizes recently, the 275/65/20 are a hair taller and bit narrower
Wrigley17
I am also interested in this. I have a 2015 with factory set up. Wouldn't the 275/65/20 tires be slightly taller and wider than my stock 275/60/20? I'm looking into a simple level and see that bilstein 5100 shocks are the most popular route to go. What is the go to tire size for 2.1 or 2.8 setting? Would it be 285/65/20?
iam_canadian22
northern ontario
275 65 20 will be slightly taller but same width as stock 275 60 20, 275 is the width, that number doesnt change the width doesnt change, keep in mind tire manufactuers actual measurements vary from one another, so a 275 from x brand may be a bit wider then a 275 c brand, in a duratrac i love the 285/60/20
Why So Serious?
RI
so would I just need wheel spacers for 285/65/20 with stock everything 2005 1500?
also, would it be ok to run that size if I never plan on upgrading my axels and staying with my 3.92 gears? and would stock control arms be fine?
the only thing I might do to the suspension is put some 5100's up front set at 2.1".
jknappen
jknappen
Kentucky
What are the biggest sized duratracs i can run with no spacer on the rancho quick lift on stock 20s that dont rub or anything?
huff2462
Baltimore, MD
I'm running 285 60r20 Goodyear All Terrains with Bilsteins set at 2.1 on stock sport wheels.
I think it's a great looking combo!
jknappen
jknappen
Kentucky
Good looking set up. Wonder if duratracs would work and not rub or anything
iam_canadian22
northern ontario
No spacers needed, they are only needed for 35" tires
poweredbyhemi
Newbies,the duratrac is barely any bigger then stock & stay away from stiff bills,think of them as chrome plated turds.
RamRMK
Vt
I have 275 65 20 duratracs with a HBS levelImageUploadedByTapatalk1443885003.155567.jpg
No rubbing, no issues and wearing great. Put them on in December or January.
alphaprojects
