285/75/17 with no level?
Yellow98stang
Been searching and can't find any pics.
I'm swapping my stock 20's for rebel wheels and about to order tires. Stock rebel tires are 285/70/17, and actually a hair shorter overall than the stock 275/60/20's.
The 285/75/17 toyo at2's come in the extreme and are .9" larger overall diameter. Anyone running this tire or size on a stock 4x4 sport?
Thanks,
Dan
lharrell79
The AT2 285/75R17 is listed as 33.9". So, it's roughly an inch taller.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Looks real good, tires fill up the finder wells nice.
Yellow98stang
Yellow98stang
Thanks! I was concerned it would look a little squatty in the front without a level, but it'll be fine. I can't find a clear answer on ball joint issues or not with any leveling kits, bilsteins, or fox kits...
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Running mine at 2.8 with stock uca and no problems so far.
pretty safe at 2.1 I dont think anyone has had a issue set at that with the bils.
Yellow98stang
Yellow98stang
I had no rubbing back then. Wheels fit fine as they were stock rebel wheels. I ended up doing falcon shocks and struts leveling the front and running 35x11.5/17' on method wheels later. That required trimming the front inner fender a little.1000007722.jpg
One Mile Up
Colorado
6.4L Hemi
Sorry for the crappy pic... but I literally just had these Toyo Open Country A/T III's in the 285/75R18 flavor mounted up on my factory wheels. Filled out the wheel-well a bit more and they are a bump up in ride quality from the 6 year old factory Goodyear's that they replaced -- no rubbing whatsoever. :waytogo:
Arturo Rojas
