2wd 2" lift
Tristanbush1250
Planning on lifting my 01 ram(first truck) looking for some helpful advice
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Need a lot more info then that... what sub model, is it stock, how much lift you looking for.... so on so forth.
Tristanbush1250
Tristanbush1250
Sorry, like I said first truck. Its a laramie SLT club cab.....all stock except a K&N filter and i'm wanting 2 or 3 inch lift. Leaning towards 2
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
whats the purpose of lifting a 2wd? not gonna go off roading with it or climb any hills or anything. waste of money on a 2wd IMO
Merc225hp
NA
truck
gas
You can do a body lift or a coil-spacer under the front spring and a taller block that goes between the diff and the leaf spring or a ad a leaf that fits in the leaf spring pack.
As for not being able to wheel a 2wd soooooo wrong there, I have wheeled 2wd cars/trucks/vans and had a blast doing it.
TexasRammer
College Station, TX
Lol I take my 2wd through a whole lot more than most people with 4x4. Limited slip 2wd can be just as good.. And a lot of people lift it for looks too..
Johnn123
Ontario
Plenty of options posted here, alot easier to pick based on what size tires you want. You should be able to clear a 33" tire with a 2" lift.
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
i have 32in tires and my truck is lowered an inch in the rear. they rub a bit though
