2wd 3in to 6in question
thestig_wj
I have the rc 3in lift and plan on buying 3in spindles and I have a few questions....
1)can I use same shocks
2)what size rear blocks will I need
3)will I need extended brake lines
4)is the crossmember drop necessary
TexasRammer
College Station, TX
1) yes
2) probably 3". go measure how much rake you have now if any, then add 3" and that will be the size for a complete leveled look
3) not sure on that one. do the 6" kits say you need extended lines/come with them
4) dont think so because the spindles dont mess with your angles. but not positive on that one
T
thestig_wj
Thanks from my research that's what I've read, just needed to hear someone else say it
Jus10case
