2WD leveling kit LARGER than 2inches??
srqFF
Sarasota FL
Does anyone know of any companies that make a kit larger than 2 inches for 2WD?
I wanna be able to comfortably fit 35x12.5's but also by raising the rear.
Readylift makes a 2.5/1.5 kit I believe but it's only for 4WD.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Daystar. Go on performancelifts.com.....
Thats were I ordered mine. Its a 2.5" but adds 3" of lift.
Sent from my VS920 4G
WhiteExpress
Midland, TX
Only if you step up to 4" for a spindle kit.
That being said, I'm sure if you find the specs on these spacers, something off a Chevy would likely work. The coils are likely the same diameter.
They likely don't offer more due to suspension geometry constraints (guessing here)
srqFF
srqFF
Sarasota FL
Well i had planned on going with the 7 inch CST lift, but i as hoping to find something a little cheaper to hold me over for a while.
T-Rob
I don't think they make them higher than 2" for safety purposes howeve you can always add that then add a body lift to the height you would like they run from 1.25" to 3". And gives you sort of that same look as the CST lift and this saves you roughly $500-$600 also.
