2WD Leveling kit
usmadad
5.9 CTD
New to the forum and need advice on raising the front end on my '04 2500 CTD 2wd. I need to raise it about 2-3 inches. I just put Michelin 245/70r19.5s on it and leafed up the rear end (tow a 43' toy hauler with 3800# pin weight) and need to level it out. I've read some of the posts here and it seems that Hellbent is the way to go. Problem is they don't manufacture a 2WD lift. Any suggestions for steel lift/spacers. I read that I need to adjust the torsion bar as well. True?
Thanks in advance...
DZ
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Might have to go with Helbent steal. I had very little luck finding anything for 2WD's also.
U
usmadad
5.9 CTD
Hellbent advised they did not make a 2wd lift...will their 4wd fit on a 2wd?
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
you will be much better off with spindles. I had 2.5" spacers on my 2wd 2500. Upper control arms and ball joints did not like it at all.
Raadz
