I recently purchased a 2012 crew cab 3500 slt and want to replace the front seats. Just wondering what seats will fit?
Thanks
I can’t offer as much help as OnSale could, but if your truck doesn’t have airbags in the seats it would probably be best to just leave the yellow one unplugged. The gray plug 12ga red and 12ga black should give you power movement and lumbar, I can’t help much on anything like heat/vented seats or memory seats or any of that, but I believe most of that runs through the gray plug IIRC."I just had to tap into the wiring under my seat for the old seats to power the new seats since the plugs didn’t match."
What did you do there? I'm looking at a set of 2015 Limited, but they have the SRS Airbags in them and my Laramie MegaCab interior does not have them. Can I plug these up? Or will the electrical system have issues??
How do you do this I have 2015 seats going in my 2012… the airbag wiring is separate from the actual plug. Do you have pics?Any 09-18 Ram Crew Cab seats will fit. I have a 2012 and installed a set of black sport heated and cooled leather seats from a 2015 and love them. I just had to tap into the wiring under my seat for the old seats to power the new seats since the plugs didn’t match.
U got any pics im trying to do the swapI can’t offer as much help as OnSale could, but if your truck doesn’t have airbags in the seats it would probably be best to just leave the yellow one unplugged. The gray plug 12ga red and 12ga black should give you power movement and lumbar, I can’t help much on anything like heat/vented seats or memory seats or any of that, but I believe most of that runs through the gray plug IIRC.
Good luck
