35x12.50r20s
RABIDFOX50
I have a 2017 RAM 1500 Night Edition Sport 5.7 HEMI with a ReadyLift 4” SST lift and level kit installed. I still have the factory 20”x9” OEM wheels. I was told that I can mount 35x12.50r20 tires on it without any rubbing or trimming. Is this true? Many thanks!
co-pilot
houston,tx
Hi RABIDFOX50 .....welcome to the forum.... sorry I don't have a direct answer but yes that tire will fit your rim and with your 4" lift turning clearance shouldn't be a problem, the only issue is will the tire rub on the upper control arm from the tire bulge ???
CanuckRam1313
Ontario Canada
2023 Warlock
I'm running LT295/65R20's on my OEM 20" black rims with zero issues.
I have maybe a finger width between the inner tire sidewall and my UCA.
However, mine are Michelin Defender LTX M/S tires and not aggressive AT's.
You will likely need to use a spacer to clear the UCA's with the tires you're looking at.
I'd ensure you purchase top quality spacers, and keep them to an absolute minimum thickness to meet the requirements to clear the UCA's.
I may get flamed for saying that, but I'm personally not a fan of spacers, especially thick ones.
Just my $0.02 though.
R
RABIDFOX50
Many thanks. I decided to go with XD 18x10 wheels with a -24mm offset with the 35x12.50r18s so I would not have to run spacers
Timkll
