4:56 gears
94ram1500
jay oklahoma
I picked up a used ring and pinion complete unit with the trac loc lsd bolted on. one of the gear teeth looks worn down, it's not broken off or galled, the pinion looks fine, no damage there, aLso some of the teeth have polished spots on them, is the ring gear still usable?
dapepper9
Iowa/Nebraska Border
5.9L V8
Your photos aren't viewable. If teeth are worn down i wouldn't run it and considering TracLoc sucks, without more information I'd be passing on it
94ram1500
94ram1500
jay oklahoma
I've had incredible performance out of the trac loc unit in my bone stock truck. the photos should be viewable now
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Yeah the Trac loc is great, until the clutches start to go, spewing a fine mist of metal, fiber, and clip material into the gear. The pinion bearing gets an ulcer and the carnage is swift and destructive.
Okiespaniel
magnum, 5.9
eh. by the time that happens you're ready for an upgrade anyways. :rocking:
You're buying a used ring and pinion with two suspiciously worn teeth and lots of gear wear. How new do you think the clutch facings are?
It'd be like using Dodge Charger springs for add a leafs.
You'll find that the 2nd gen Dodge is a harsh teacher when things are done half-assed. But go for it! I just wish you'd stop asking and try it!
94ram1500
94ram1500
jay oklahoma
no need to be an *******, I used to respect your advice, you know what you're talking about and I looked forward to your responses. share your knowledge with no judgement, don't be a **** head.
