FlatbedHemi
I know there are a couple threads on this topic, but I didnt want to hijack those threads with a slightly different, but specific question, so I will start my own.
Getting closer to making the swap to lower gears, but for the life of me I cannot decide which set to go with. I am looking at 4.56 and 4.88 options. I am currently running 3.73s with 34” tires, getting roughly 12-14 MPG (EVIC) depending on which seasonal blend of fuel is available. That’s unloaded and running about 75mph.
I know the gears in either ratio will be a huge upgrade, and I know that a lot of you guys are proponents of the 4.88 from a performance standpoint, but what about fuel mileage? Yeah, I know, Its not a Prius. But, since most of my driving is 20-30 mile+ stretches of highway driving I would like some real world comparison of fuel mileage for each gear set. I know each set has potential to improve my mileage by allowing the engine to work less by keeping it in the power band, taking less throttle to accelerate, as well as letting the engine run in ECO more often. But, at so e point there has to be a point of diminishing return. If both sets will net about the same MPG, then I will go 4.88, but if 4.56 has better economy, it might be worth it to leave some torque on the table for the sake of highway MPG. I just need some real world numbers for comparison.
Since I cant really afford to try one gear-set then the other, I would like to ask anyone who has done the 4.56 or 4.88 swap to post your fuel mileage on stock gears and on the new gears. If I can get some input I certainly would appreciate it, and it will help me make up my mind.
OR, if anyone that sees this lives in or is traveling through east Texas and wouldn’t mind letting a stranger test drive, that would be great too.
