4.7 mods
vinper
while im working on my sons water pump any other improvement I should do while down , I saw one to remove check valve when changing trans fluid ,
V
vinper
should I run seafoam in it before changing the motor oil?
PCA4208
Albuquerque, New Mexico
You can do sea foam at anytime. And what mods are you thinking of doing? Yes that check valve should be removed or replaced.
V
vinper
im just thinking of preventive maint. not performance unless fuel savings .
PCA4208
Right.. Well sea foam, new air filter, maybe a pcv valve. Oil change unless already done. New plugs and wires. That should do it, that's what I usually do do old vehicles, or just maintenance.
Raadz
