47 RE transmission quick connect on oil tank pressure hose
johnanga13
Salmon Arm BC
Hey there 1996 ram 3500 5.9 diesel
I ordered a new transmission cooler line because mine is leaking. The new one showed up and it has flared ends with threaded fitting on each end. My transmission has quick connections on both ends. I’m sure this is an upgraded line but how do I connect it? I’m guessing that I need to change the fittings on the actual transmission?
Please help
Thanks in advance
cirioboar
