NewfieDan
Not sure if anyone else has seen or had this issue but 3 times now in the past 2 weeks my truck has done the same thing. I have a 2013 1500 longhorn, 3 times now when I have started the truck the 4wd controls and the comfort controls become non-operational (no lights or function). It will not clear itself or start working. The only solution I have found is to turn the truck off and wait a min for the truck to actually power down then start it back up again. At that point everything is working again. Right now its just annoying but I would like to try and figure out what the issue is before it becomes worst. Does anyone know if theres a common module between the comfort controls and the 4wd switch. My guess is the truck isn't seeing the switchs on startup and then ignores them after.
Thanks in advance.
Dan
Thanks in advance.
Dan
