Mack
- Joined
- Aug 11, 2014
- Posts
- 32
- Reaction score
- 2
- Location
- South Carolina
- Ram Year
- 2002
- Engine
- 4.7 Magnum
Could you explain to me how you did the lowering? Just rear end? or front and rear? And how hard? Expensive? Any major changes?
I think I slightly understand this better now. So if I were to do a 2/4 or 2/4.5 drop and I wanted to put together a parts list it could be as follows:
Front:
2" drop spindles
Rear:
4" flip kit
Possibly helper airbag springs
New bump stops and shocks all around?
Am I getting this right?
Also do you have the part # for the notched spindles? I can't seem to find them...
Thanks.
Now is there any benefit to going with the drop spindles over torsion keys (I think that's what's in the GroundForce kit).
The reason I ask is GF is the only company that makes a lowering kit for the 4x4s. Not that it is ridiculously expensive, but if I can save money and it is better for my truck by doing the drop spindles than I'll just part a lowering kit together. If not, and I know this would be easier as well, I'll just get the GF kit and lower my truck with that.
Edit: Also is there any other way other than a flip kit to lower the rear 4"?
Ok thanks. And with the 4" drop in the rear would I need to notch the frame or would I be ok without a notch?
Sent from my SM-N900V using Tapatalk
Thanks guys.
So I found 4" lowering leaf springs from Belltech. If I combine that with the 2" drop spindles from McG's and then new bump stops for the rear That should be everything I need to lower my truck 2/4?
New drop shocks for the rear also. The front stock ones will be fine with the spindles.
Ok thanks!
One last question. After looking at the leaf springs they are actually like 3-3.5" drop. If I did drop shackles in the rear with the springs to get the full 4-4.5" drop I'm wanting I can do that right?
You could do that but you'd be close to almost having to do a c-notch. You might be able to trim the bumpstops down and leave a little on them and get by with it.
great breakdown for the 4x4 guys. I have now found what I will be spending my deployment money on! So all together looking like 900$ in parts?
