Hero6
I have read several posts that state the 5.9 flex plate should have a weight/weights tacked welded on from the factory. As my engine is out for a rebuild, I noticed mine does not have any weights on it. It actually has a series of several holes drilled in it, I guess for balance. No sign of any weights being previously installed. Is it possible the flex plate is from a 5.2? Did not notice any issues with the operation of the truck or motor (other than low compression on 2 cylinders), this is not the original motor, but it is a 5.9 which is what it came factory with.
Edit: Meant to say Flex Plate, not flywheel in the title, but cannot seem to edit it.
