I've got a 5.9L Magnum that I've purchased the Aluminum manifold plate for. The engine currently has scattered misfires on various cylinders (most commonly 5 and 1) and the cat and O2 sensors have just been replaced. I'm also replacing the water pump and timing chain when I install the plate.
The truck's main purpose is to tow a gooseneck 13,000# horse trailer (13,000lbs, meaning 19,000GVW when fully loaded) and struggles up big grades. (On huge hills, I have hit grades where the truck can't get past 10-15mph in first gear, but the old girl does get up them without having to shift the transfer case into granny gears.)
If I wanted to add some towing performance without breaking the bank, and I'm already going to have the plenium off the engine, what would you guys recommend? (Obviously solving the vacuum leak from the plenium issue is going to help alot) Let's say I don't want to add more than $500-1000 to the job for performance improvements, and only if they make sense. (IOW, pulling grunt from 2200-4000 rpm is all I care about. Not interested in racing or showing off.) I won't be offended if it turns out that the answers is that there isn't much I can do without spending way more than that.
Roller lifters?
Better muffler?
Something else?
Roller lifters?
Better muffler?
Something else?
