Mopar M1 part numbers and parts list.
Merc225hp
NA
truck
gas
Mods if we could get this stickied that would be great.
Some basic M1 info
The M1 2 bbl mpi is a true bolt on intake, provisions are there to install all the needed sensors.
No messing with the fuel crossover line or relocating the IAT.
Installing the M1 2bbl mpi on a stock motor will work but there will be a small loss in lower rpm torque, this can be regained with a couple of mods like the use of a tuner and 1.7 roller rockers.
The more mods you add the better it responds.
Installing the M1 2 bbl mpi eliminates the plenum pan altogether.
Installing the M1 2 bbl mpi also gives you more room to get at the distributor cap making tune ups much easier.
• Important note; There is a 4 bbl version of the M1 mpi intake that uses an adapter to go 2bbl do not get this intake.
V8 SINGLE PLANES + - MPI FUEL INJECTION
P5007398AB 2 bbl mpi, aluminum, single plane, magnum direct replacement, w/EGR port 1992-96 5.2/5.9 same height as stock manifold. Requires installation kit P5007638
P5007852 2 bbl mpi, aluminum, single plane, magnum direct replacement, without EGR 1997-02 5.2/5.9 same height as stock manifold.
*Note: 96 year trucks check to see if you have an egr intake mine did not.
MAGNUM INTAKE INSTALLATION KIT
* Note; I recommend getting this kit with either intake.
P5007638 Magnum intake manifold installation kit.
Intake Manifold Attaching Bolts
A complete package of bolts required to attach the intake manifold to the cylinder heads. Set of 12.
P4876772 Intake Manifold Attaching Bolts (5.2L/5.9L Truck Magnum/Jeep Engine)
Intake Manifold Gasket Set
Custom fit for use with Mopar Magnum engine cylinder heads. Kits come complete to service one engine set. Includes gaskets, end seals, O-rings, and distributor seal (where applicable).
P4876049 Intake Manifold Gasket Set (5.9L Truck Magnum/Jeep Engines)
