5 speed manual transmission ,
Canns
Will not shift. Stick Acts like neutral but WILL move forwards as if In 1st. Will not drop into any gear or actual go neutral.
JPT
NY
2015 Big Horn
If I am reading this right... You have a stick and you cant change out of a gear? If so, try to change the gears when the vehicle is off, if you can, it is the clutch, master cylinder or slave cylinder. Either way, you aren't actually able to engage the clutch.
Mine did this as the clutch was going out, it fell to pieces when they pulled it.
