55W digital ballast.....
KozzyJr
Ontario, Canada
hey guys im in the process of install in jj heads and fogs. just wondering where you guys install your ballast for your fogs?
Note: 2012 sport
any pointers would be great.
Dawizman
Alberta
I mounted mine behind / under the headlights, right next to where I mounted the headlight ballast. There is a support underneath the lights, and I just used tek screws to hold them down. They seem to stay nice & dry up there. I wish I had a picture for you, but I don't.
WhiteExpress
Midland, TX
I only have the 35W fogs, so they are smaller, but I just 3M taped them to the bottom of the housing. Worked flawlessly. It was quite a PITA to remove them when I thought I was going to sell the truck. This is where they will be remounted to, whenever I get around to it.
Liquidoxygen
Edmonton Alberta Canada
2500 Diesel
I have a thread posted where I mounted them. They tuck onto the frame rail perfectly and the wire Harness has a nice straight shot to the bulbs.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
there is a lip where the tow hooks go. Thats where mine are. zip tied to that.
K
KozzyJr
Ontario, Canada
thanks JJ. Man what a PITA to find locations for mounting everything. to make it look like factory.
danfordfwh87
washington state
i just self tapped mine to the side of where the tow hooks install and then used heavy duty zip ties for reinforcement.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Exactly here.
Sorry I couldn't help further when you texted.
I'd snap a pic for you but don't have my truck till tomorrow :Violin:
Did you get everything connected and up and running?
Pics?
K
KozzyJr
Ontario, Canada
Exactly here.
Pics?
yeas i did. look sweet but i need to do some major adjusting. body line along with light adjustment.
K
KozzyJr
Ontario, Canada
why does the light cut off like that on the left. when i made sure the adjustment tabs were the same before putting the fog light in..... :mad:
fastNugly
Toronto, ON
So the second one is the fog cutoff?
Btw, it looks good
fastNugly
Toronto, ON
first it lows+fogs, second is just fogs
Cant recall if mine does that....but there is no way to really adjust the fogs as we do with the heads....but maybe Jeremy can chime in here
fastNugly
Toronto, ON
From what i see in the pic too, you need to raise the drivers side fog up a few.....just look at the arches in the bottom of that pic. They dont line up or are not the same height.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
fogs you adjust with the white dial on the bottom of them. :D
GPRADA
