hunterdan
- Joined
- May 7, 2018
- Posts
- 1,182
- Reaction score
- 1,561
- Location
- SE PA
- Ram Year
- 2019 classic
- Engine
- 5.7 Hemi
After digging in and doing some research, it seemed 5th gen rear coils were drop in replacement options, and offered a variable rate coil compared to what we have for the 4th Gen stock. Their Off-road Package (ORP) springs offered an inch of lift over their normal ride height option. When digging into it further, the ORP rear coils are stupid cheap, like $25-30 a piece cheap, part number 68262684AB.
The issue I was facing was that last summer I replaced the rear shocks and coils with Bilstein 4600s and superlift 2" coils. The 4600s were too short, literally nearly completely extended at just normal ride height. So, I had to add an extension. The rear, with the superlift coils, sat higher than I wanted, somewhere around 2.5" total lift over factory. Gave me a lot of rake, and I believe these coils were stiffer than OEM. While initially, they seemed to ride better than what I had, OEM shocks, springs and 1.5" spacer. I started finding that the rear did not want to stay planted. Likely source was probably the control arms, but I was still sitting higher than I wanted in the rear. If I had a constant 500+ pound load in the bed, it likely would have sat closer to where I wanted. So, after doing some digging, I decided to order the ORP springs from @AllMoparParts.com and had them here in 2 days, ordered a set of knockoff rear control arms, and had already had a set of rancho rs7mt shocks delivered. I went with the ranchos because the specs on them list them as a progressive rate valving instead of digressive, hoping they'd ride a little softer than the 4600s. Saturday evening I tore into my truck and had the driver's side stuff replaced. Sunday morning, I knocked out the passenger side. Quick drive around the block to get things to settle, was showing I was sitting at about 1.5" of total lift over factory. Much closer to where I wanted to be. Ride quality was still up in the air. It's hard to try and isolate the front from the rear, especially when traveling at higher speeds. I didn't want to make any judgement until I can test it out on certain parts of roads I use to drive to work. Where these bumps would cause the rear to want to skip and shift towards the outside at highway speeds. Well, after a drive into work, I can confirm that the truck is far more planted in the rear, the rear suspension feels less harsh over small to medium bumps in the road. The 5100s up front feel stiff, and jarring. I'm really disappointed I spent the money I did on these, and wish I'd have gone a different route to begin with. So, all that said, if you're looking to lift the rear of your 1500 about 1.5", go with the coils I listed. The price is similar to that of a spacer lift, but with better ride quality, and should handle heavier loads slightly better, being a variable rate. The following pics are before removing the superlift coils.
