6” lift with 17s
rwhjr
maryland
procomp 6” lift on a 2017 1500
I want to possibly get a set of 17s with 37x12.5s
Will the procomp lift work with 17s?
What’s the allowable backspacing to make it work?
Anyone know more about this than I do?
For ex: will a 17x9 -12 fit without issues?
rwhjr
rwhjr
maryland
No one knows if 17s will work with a 6” ProComp and what offsets?
Guess I’ll hafta call ProComp and ask...
buddy guy
alberta
do you have a 4wheel parts you could call? I would give them a yell. I would rather talk to guys who install them for a living myself.
MarshRam
2014 SLT 4x4, 2012 ST
Well, I got 35's on 20" wheels with a 6" procomp lift if that helps any.
rwhjr
rwhjr
maryland
I already have that as well. But I feel like 17s are a different ballgame soni wanna know if they’ll work and what range of offsets...
rwhjr
rwhjr
maryland
So ProComp is telling me (the guy reading from a sheet of paper) that 18” wheels with maximum 5” backspacing is the smallest wheel I can run. Anyone know otherwise?
He didn’t seem like he knew for fact...he kept saying “it says here we cant run 17s”
So does anyone know of anyone running a 6” ProComp with 17s on a 4x4 4th Gen???
Otherwise it looks like the smallest I can use is an 18? Which isn’t the end of the work but I was really starting to want to run 17s with 37s as of late...
MarshRam
Don't take this as gospel, but maybe this is the reason or one of them.. There is a solution!
The tpms valve stem might rub the tie rod. Provided a pic below on my 20" wheels, -44 offset. If I put the valve stem cap on that, it will rub the tie rod and blow it, I will no doubt have a flat instantaneously. That's how close it gets. I imagine with a 17" being a smaller diameter, it could place that stem even closer.
However, they do have shorty stems you can purchase to solve that problem if that is in fact the sole reason.
ChloeBrooks
