6.1 Cam worth it ?
ramhunter9
P-Star Jeep Wrangler
like the thread says ....
Silverbullet08
Persona Non Grata
for your truck? no, 6.1 has no low end which is what u need so i would def. look getting it reground or another cam
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
6.1 is never worth it...doesnt matter what kind of truck it is. there just arent enough gains to merit all the work/expense of doing the install. there are much more aggressive cams that put out much better numbers, but still run perfectly fine on the stock tune
RubberFrog
6.1 sucks
it might be ok in a rc, but your mega would become a **** with that cam.
ramhunter9
ramhunter9
just checkin , buddy said he could get me one for pennies . never mind . I dont think AF would come to illinois to install that lol
RubberFrog
How cheap is cheap? Get Stu to regrind it for you.
ramhunter9
ramhunter9
cheap as in like pay shipping , didnt think you could do a re grind on that cam ?
truckin151
2013 sport
If its that cheap then get it and get it reground, otherwise get it and sell it for a bit more
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You have seen my vids also.. mine is a 6.1 with a Spartan regrind which is more of a topend cam. Yes you will lose low end but the 6.1 cam is bout the same size as the comp 268 just on a wider LSA. Frogs grind is for trq mine is for hp. If you never go to the track then go with frogs grind and have a blast just know the power rolls in later on these.
ramhunter9
ramhunter9
i need low end ... as the truck is 8k pounds plus in weight . the 4:10's help but would like more umph
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Wonder if you would get more out of bumping up to 4.56 gears to get the low end your looking for along with a Frog regrind and you will have the best of both worlds. I think one of the more aggressive trq cam is gonna be the KRC210X.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Anything with enough power it sounds like he is looking for will need a tune to keep the A/F correct. More or less it depends on what kind of money your looking to spend and what your using the truck for.
Silverbullet08
Persona Non Grata
sounds like u need to join the crazyfrog world. i know i am lol :D get it before october and make your way down here for the install
truckin151
2013 sport
There are plenty of lowend cams that will run good on a canned tune, wont be perfect or tapping into its real potential but there are some out there that will give you a nice lowend without a custum tune.
RH do you even have a tuner for the tank?
I'll come install it for you if you take me out so I can shoot some of those guns you got :D
