NewBlackDak
- Joined
- Feb 9, 2014
- Posts
- 1,107
- Reaction score
- 682
- Ram Year
- 2025
- Engine
- 6.7L Cummins
Looking at buying a toy hauler that has a gvwr of 13,500lbs.
I won’t max it out but 13,000lbs is likely.
I have an ‘18 6.4 with 4:10’s. If I’m not happy with the pulling performance I’m going to consider gears. I’m wondering if 4:56’s would put my first gear final ratio close to the new 8 speed?
after looking at the chart on the first page. I’m thinking 4:56 would be best. I tow at 60-65 tops. 4:88 might be to much?
how big of an improvement can I expect? If I’m going to spend $2500 I sure in the hell better notice it!
I’m on the west coast and pull some big hills. Cajon Pass and the hill from bishop to mammoth are the norm.
My TH is 14K GVW, 9800 dry.
I’ve had 20 gallons of fuel, a Maverick max, 2 dirt bikes, 80 gallons of water, and food for 6 people for 4 days loaded up. Towed from home(4500ft) a remote spot inthe mountains(7300ft) without any issues. I take it slow and easy towing.
The swap from 4.10 to 4.56 isn’t worth the expense. 4.88 should be the minimum if you’re thinking about upgrading.
